hazzamondo 10 Posted June 14, 2012 hi guys recently purchased a 91 G60. Last night the dash lights did not illuminate, so checked today and the fuse had popped replaced the fuse then when i pushed the headlight switch it went pop straight away. Ive stripped down round the clocks to check for trapped wires and there is nothing i can see. I took the numberplate lights apart and the earth connection to this has snapped, would this cause the fuse to keep blowing?? Or is it the common problem of the headlight switch ??? cheers Quote Share this post Link to post Share on other sites
