Delta-M 0 Posted April 8, 2004 For those with coil trouble- When the HT coil went down on my '93 2.0 16V I found much money was to be saved by only replacing the coil itself (the transistor mounted to the aluminium bracket was, apparently, not at fault). The coil alone cost about 19.00 from GSF (a replacement coil for a mark II Golf 1.6 I think, with the pin connectors- just made sure that the plug leads fitted OK)- the cheapest corrado coil assembly (presumably with the aluminium bracket + transistor included) rolled in at around 140.00 :shock: I've done over 1000 miles since & all seems well. :) Quote Share this post Link to post Share on other sites
