Dodger 10 Posted June 20, 2012 Just as the title says, everything has been working perfectly, windows roll up when I lock it, doors lock from both pass and drivers side. When I try to unlock it the vacuum pump works, and the door locks pop up, but the doors will not open. Even if I disconnect the vacuum pump they still will not open. If I climb through the hatch and pop the hood, disconnect the battery. I can unlock the doors with the key. Reconnect the battery and all works perfectly again. In a few days or hours, back to not unlocking unless the battery is disconnected. Since I can not unlock it with the central locking pump removed, what else is in the doors to keep them locked? Dodger Quote Share this post Link to post Share on other sites
