lgs
Wheel size
Hi all just got my new rims today bbs but I have a problem they don't fit the front is 7.5x 17 with 205x40
And the back are 8.5 x17 with 205x 40 the rims are 17in with er35 the front need a 20mm spacer and the
Back 10mm to clear the front also rubs on the calliper dose any one what size will fit with no Spacers I can live with the back spacer but I need to do something with the front, Regards liam
Edited by lgs
something does'nt add up here mate as et35 & 17x7.5 should go straight on, no spacing required! Are you 100% on the offset etc??
Yes the et is 35 when you fit the front it hits the calliper you need about 20mm to clear the wheels are bbs rs,s the speed line wheels I have on have a et of 45 dose make a differents
Edited by lgs
