20valver 0 Posted April 8, 2004 I'd chosen to revert back to the standard pulley and chip until i have enough cash to get an SNS and a proper set up. Swapped the chip no probs... Came to remove the pulley and it won't budge. I've removed the bolt in the middle, but the 68mm just won't shift. Any tips in getting it off, bit scared of getting 'tuff' with it as don;t want to stress the chargers internals. Oh and if I ran the std chip and a 68mm, would it just harmlessly bleed of the extra boost? Quote Share this post Link to post Share on other sites
W3RKD 0 Posted April 8, 2004 u need a 3 legged puller.. but... you brought leews first corrado didnt you ? the chip in that car is ok will not damage your car untill you get a sns one. Quote Share this post Link to post Share on other sites
