exturbo2003 0 Posted April 12, 2004 okay has anyone got a wiring diagram for the G60 if so can you help identify a wire for me if you were to turn the fuse box round and look at the back of it there is a series of multi-plugs top right hand corner third plug in it has 5 wires in it black with a blue trace brown with a blue trace brown purple with a blue trace red with a yellow trace i need to know what the red with a yellow trace does as with out a live supply up it you cannot turn off the engine. there is a spur wire tapped into it and pushed into a relay slot on the front of the fuse box. i tried to remove the multi-plug but is stuck tight so can anyone help please Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 12, 2004 The red/yellow could be the feed to the fuel pump perhaps. Does it go up and then down behind the carpet towards the sill? Can yopu tell us the plug number/letter? Gavin Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 12, 2004 no i couldnt see the plug number. its not the fuel pump as it would not run if it had no power and it needs 12v to kill the engine Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 12, 2004 You know that you have to slide a clip across before you can get the mulitplugs out? That plug letter would make all the difference. The Bentley manual says what each one does and has pictures. Gavin Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 12, 2004 wheres the clip please mate Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted April 13, 2004 the clip slids through the centre of all the fuse box, on one side theres a small notch that you can pull to realise the plugs. i thought red and yellow was to do with the fuel pump too. wiring diagrams http://volkswagen.msk.ru/index.php?p=page09 http://www.snstuning.com/ Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 13, 2004 okay the plug letter is M anything on that one please mate Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 13, 2004 Blue/black is power to spoiler switch amongst other things. Brown/blue is from-to fuel gauge sender. red/yellow defo power to the fuel pump brown is earth for fuel pump purple/blue is the other side of the gauge sender Although none of that info explains your problem. But it has all the right colours so must be the right loom. Gavin Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 13, 2004 can you tell me if they go through any relays please :D Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 14, 2004 The wires in plug M are all outputs. When I get in I'll have another look. Obviously the red/yellow comes from the fuel pump relay but I'll confirm details after tea. Gavin Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 14, 2004 cheers gavin Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 14, 2004 relay 12, bottom right hand is the fuel pump relay, the source for the red/yellow.switching for that comes from the Digifant ECU. I'll take the bentley to work and scan the pages and email them to you. Much easier I think. Cheers Gavin Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 15, 2004 top man gavin thanks Quote Share this post Link to post Share on other sites
