jibsterrado
Sunroof Problems! NEED HELP!
Sunroof on the corrado has gone bang, been looking for a replacement & having no luck in finding another, is there other vw sunroofs that are compatible with the corrado??
Any input would be greatly appreciated!
Thanks
Hi. If you do a search you will find the information you need. Ive changed both of my sunroofs and used a Golf mk3 mechanism on both, and its a straight fit. You can also use a passat B3 sunroof. you need to remove you head lining and sunroof panel, then remove the old mechanism which is bolted to the roof, then do the reverse to fit the new mechanism making sure its well greased etc.
Hope this helps a bit.
More than covered already and posted in the wrong place.
