paddymack
door lock problem
so my car locks fine, with the key or with the remote. but my passenger door doesn't unlock very often. it wont unlock even with the key which is hard to turn to the unlock position. the inside door handle wont open it and either will the pin on the inside either.
anyone had this trouble?
I think everyone has had that problem or similar.
Sounds like you're well and truely siezed up. Do you have any way at all of getting the door open?
I would say you need to take the doorcard off and get the lock mechanism out to have a look at it to see if anything is stuck. WD40 to loosen it up and motorcycle chain silicone spray grease to keep it moving.
