paddymack 10 Posted August 23, 2012 so my car locks fine, with the key or with the remote. but my passenger door doesn't unlock very often. it wont unlock even with the key which is hard to turn to the unlock position. the inside door handle wont open it and either will the pin on the inside either. anyone had this trouble? Quote Share this post Link to post Share on other sites
Bazmcc 0 Posted August 23, 2012 I think everyone has had that problem or similar. Sounds like you're well and truely siezed up. Do you have any way at all of getting the door open? Quote Share this post Link to post Share on other sites
paddymack 10 Posted August 23, 2012 Sometime it open some time if i keep pulling the door handle while i turn the key, what need to be done to free it up? Quote Share this post Link to post Share on other sites
Bazmcc 0 Posted August 23, 2012 I would say you need to take the doorcard off and get the lock mechanism out to have a look at it to see if anything is stuck. WD40 to loosen it up and motorcycle chain silicone spray grease to keep it moving. Quote Share this post Link to post Share on other sites
paddymack 10 Posted August 23, 2012 I got lucky! sprayed WD40 into the lock where you insert the key a few time all day and its working sound now thanks BAZmcc Quote Share this post Link to post Share on other sites
