dingdong 10 Posted August 27, 2012 No brake lights just came home and got no brake lights any ideas anyone will have to look tomo now cheers damien Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted August 28, 2012 Check the fuses first, fuse 20 I think is the one for rear brake lights. See if its blown, if it is then replace it with a new one and try again. Also try a search on here or google, there is loads of information that will help you. :) Quote Share this post Link to post Share on other sites
Wild-Animal 2 Posted August 28, 2012 There is also a switch forthe brake pedal, when you apply the brakes make sure the switch is being pressed. This activates your brake lights Quote Share this post Link to post Share on other sites
Stonejag 10 Posted August 29, 2012 If the fuse has gone you'll probably find a duff bulb as well, so be prepared to change it! Just so it's written down somewhere, cars with auto boxes use the brakelight feed after the fuse to control the lock that prevents you shifting out of P or N without your foot on the brake. If the fuse is blown your gearbox won't unlock and you'll be stuck! (you can remove the cover and push the solenoid down manally but you'll be driving with no brake lights...) Stone Quote Share this post Link to post Share on other sites
