chopper666
wiper issues
hello
ive just had my heater matrix replaced and the wipers all worked fine before
tried the wippers and they only work now on full speed
no intermitten or other speeds work
ive checked the stalk and all seams fine on there:scratch::scratch:
any idears on whats happend
cheers
Have you checked the relays are all pushed into place properly?
ive checked all the relays on the fuse board they all seam too be pushed in
i did have the number 22 relay replaced but i thought that was just the indicator relay
thanks
The relay for the wipers is relay 99. I would change that and see what happens. Relay 99 is common in alot of vw's so quite easy to find one, or do you have a friend with a car you could borrow one off to check if that works?
