hutchyvw 0 Posted April 16, 2004 when the lights are off on my '90 16v and i press the brake pedal, the right headlight comes on, i,ve resorted to driving around with the sidelights on to stop people thinking that i'm flashing at them. :?: any ideas :?: Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted April 16, 2004 sounds like an earthing problem to me, have a thourough check of all your earthing points,, Quote Share this post Link to post Share on other sites
Henny 0 Posted April 16, 2004 Change the right hand brake light bulb... The same thing happened to KA ... The bulb has blown one of it's elements which has then managed to short onto, and weld itself to, the other element in the bulb... net result is that when you press the brakes, the broken bulb element earths through the other half of the bulb and through the front headlamp turning it on (although slightly dimmer than your headlight would normally be...) :? I've heard of this a couple of times now, but it is pretty rare... 8) Quote Share this post Link to post Share on other sites
exturbo2003 0 Posted April 16, 2004 or wrong bulb fitted :oops: Quote Share this post Link to post Share on other sites
Ka` 0 Posted April 17, 2004 phat rado, As Henny pointed out, here's the thread to my problem, exactly like yours --> Thread :) Cheers, Rica Quote Share this post Link to post Share on other sites
