Rinse 0 Posted September 10, 2012 Currently my VR6 doesn't have any alarms or anything fitted to it apart from a defunct scorpion alarm in the dash, unwired. I'm going to be picking up my old Valver (same year, 93, late) which has some form of Clifford installed to it. Will I be able to Swap over the Alarm from the Valver to the VR6 as easy as splicing the wires where they were spliced on the Valver/previously spliced on the Scorpion system? Would the easiest way to remove be following each wire from the clifford controller, labeling where the cable ran to, the colour of the cable its spliced to, then try and put it directly into the VR6 or will it not be as easy as this? Cheers! Keeve Quote Share this post Link to post Share on other sites
