Jon TDI
Compression test on G60
I've just had my G60 serviced & the garage has advised me that the compression is low & it's burning a bit of oil.
Each cylinder is about 95-110psi. What's a good pressure for the G60 to put out & what does my low compression tell me?
Replace piston rings/valve seals etc?
(not really an engine man so I would wait for better offers if I were you! :))
According to the Bentley guide (section 15.4) the compression on the G60 (PG) engine should be between 116-174psi when new with a permissible difference between all for cylinders of 43.5psi and a wear limit of 87psi.
Replacing your piston rings would be the first job IMO - it can even be done yourself if you are mechanically minded. (However, I have never done it on a car for which a Haynes manual was not available so don't tale my work for it!) If that doesn't fix the trouble then you need to look at the head I guess (not good news).
