jpowell79 0 Posted September 18, 2012 Hi guys, anyone come across their drivers door handle stop working? the door won't open from the outside which is a pain as I'm having to get in via the passenger door and climb over to the drivers seat each time I get in the car! Can't see anything wrong with the mechanism....and the door opens fine from the inside. When I open the door from the outside the handle comes towards me as expected, but its like it's not engaging the mechanism to open the door. Am hoping someone can tell me its an easy fix and that I don't have to take the whole door apart! cheers Quote Share this post Link to post Share on other sites
tony_ack 0 Posted September 18, 2012 Part of the handle mech has broken, common problem - you should be able to find more details if you do a search on here. You'll be needing one of these... http://the-corrado.net/showthread.php?10426-Door-handle-repair-kit-THEY-ARE-NOW-AVAILABLE You only need to remove the handle iirc, but it's a bit fiddly. Quote Share this post Link to post Share on other sites
