vw.classics
Wanted - Throttle position sensor / switch (potentiometer) 2.0 16V
I would have thought VW still sell these? Last time I checked they were around 40 quid plus vat. Wouldn't mind knowing the cost and availability myself so might give VW a call, will let you know if I do
  vw.classics said:
Ideally after a new one if there are any out there..?
The only sell the potentiometer whole unit at a cost of £170 rather than just the closed position throttle switch (which is all I really need)...
Anyone breaking a 16V throttle body?... or have a good working closed throttle switch (also known as potentiometer) for a 2.0 16V Corradp? Part no is 048 133 154. Many thanks.
Hi
I may have what you need, i'll check the part number and get back to you.
Thanks Rod
