swampy
Inlet manifold bolt kit vr6 1993 and others
If it helps i changed most of my engine bolts to stainless a while back.
Vr6
Inlet for both : 8x30 cap bolt -17
Dip stick bolt : 6x16 cap bolt -1
Fuel rail to inlet : 6x12 hex head bolt -4
Upper timing cover: 6x65 cap bolt -8
8x30 cap bolt -2
6x10 hex head bolt -5
Lower cover: 6x55 hex head bolt -2
6x16 hex head bolt -16
Coil pack : 6x70 cap bolt -4
Slave cyl : 8x30 hex head bolt -2
ALL require washers for associated bolts
I did thermostatt housings and oil filter housing too but unable to find the measurements at present
Paul
Sounds like a comprehensive list.. Id be keen for a similar collection should they become available..
Fuel rail to inlet : 6x12 hex head bolt -4 £2.50 (bolts for fuel rail and dipstick)
8x30 cap bolt -2
£8 for all above
£5
Coil pack : 6x70 cap bolt -4 £3.50
Slave cyl : 8x30 hex head bolt -2 £1
THOUGH ALL BOLTS WOULD HAVE A SOCKET CAP HEAD SO ALL WILL MATCH WHAT I ALREADY SUPPLY
all bolts would be stainless steel and come with washers
cheers
The only bits i was going to add to that was for the radiator brackets and the fan controller module..
The majority of that list are socket caps. Can you do standard bolts?
Not received these yet that I paid for on the 27th, have they been despatched? (I PM'd you a couple of days ago as well).
Ian.
Hey mate,
I've pm'd you a couple of times now re: my order. No response.
You've been on yesterday and today but no word..?
What gives..?
anyone know the torque setting for:
TB to manifold
Upper mani to lowwer
Lower to head?
Sorry for hijack Jake, but it maybe useful for folks :)
you could always pop down to your local engineering shop in the mean time & save 50% :lol:
---------- Post added at 12:45 PM ---------- Previous post was at 12:45 PM ----------
and have some spares!!
