g60bv 0 Posted April 21, 2004 i've just put on koni coilovers, so i bought new top mounts from c&r, but,.. as you look at them in the engine bay, the near side sit up high and the off side sits quite low,. this means to get the ride equal i have the near side strut wound down and the off side wound up. surely this isn't right, as it will effect the rebound rate. it's the same with the rears, only the opp sides, :roll: could they be different mounts. ??? Quote Share this post Link to post Share on other sites
rmn 0 Posted April 21, 2004 All meant to be fairly equal, was it a matching pair you got? They for a corrado? Strange Quote Share this post Link to post Share on other sites
g60bv 0 Posted April 22, 2004 apparantlly, standard g60 ones. looked the same, felt the same. i'm going to take it all off this weekend, make sure everything is sitting correct, and i've just had it all laser enlined. must make sure i score is all up or it'll be a waste of a ton. :cry: i've fitted loads of suspension kits before, never had this thou :?: Quote Share this post Link to post Share on other sites
