jonnykillpop
Vr6 engine mount top plate anyone?
Hello,
I bought a new drivers side engine mount as managed to get a genuine VW one, and needed as bolt was snapped in top plate, but when came the top plate is flat whereas it's angled on the one took off. Part numbers same maybe it's for a VR6 Golf. As wanted to use car drilled out and retapped and used old top plate, on new mount but as temporary measure.
Has anyone got a top plate off a knackered mount they don't need, so can do job properly, can't imagine the top plates wearing out. The mount came with new bolt and everything so only need a decent VR6 threaded plate.
I'm in South Shields, Tyne and Wear,
Cheers.
P.S. Also looking for HT leads, are these 10mm performance ones worth it. The only ones that seem to fit well are the old VW ones, got Bremi on them under W stamp so presume Bremi made for VW, can you still get them? Heard BERU's good, where can you get them?
