coullstar 0 Posted April 24, 2004 How much of a gap was there between the arch and wheel front and back when you fitted them? on the front I have a 2nd hand set that that I have just fitted and there is still a big enough gap for 2 1/2 fingers. I also fitted new shocks which could be the reason. I have Koni's on the back with unknown springs and I was going to fit the Eibach back springs but the back will be lower than the front. Have most people had to use the lowering caps? I have a set of these on the Golf but that would mean dismantling the suspension on that. :mad: Quote Share this post Link to post Share on other sites
VR6 0 Posted April 24, 2004 They should settle a little bit once you've fitted them though. Quote Share this post Link to post Share on other sites
coullstar 0 Posted April 24, 2004 Yeah but it will still look high for a suposedly lowered car even after they settle. Quote Share this post Link to post Share on other sites
kgrocott 0 Posted September 20, 2004 I have also fitted eibach springs to my corrado VR6 and the same happened to me (dropped the back by 40mm and the front by only 20mm). im now considering H&R Quote Share this post Link to post Share on other sites
Heardy 0 Posted September 20, 2004 I've just fitted them to my VR6 and it also sit's slightly higher at the front (i would imagine it would be even worse on a 4 pot engine C due to the weight) I'm planning on getting some lowering cap's to sort mine out :wink: Quote Share this post Link to post Share on other sites
20v turbo 0 Posted September 20, 2004 ,does now thoughdump the eibach's and get some H&R's its the only way to get the 4pot's to sit level,i know because i fitted them to mine with lowering caps and it still didnt sit level :x does now though with the H&R's on :D Quote Share this post Link to post Share on other sites
