VW_OwneR_85
carbon wrap number plate plinth..
just looking at my plate plinth , looks a tad out dated, dont fancy spraying it , im not normaly one for carbon wrapping but i actualy think it might look alwight in this case, anyone done it useing the 3m carbon wrap?
Would be interested to see the result's like the spoonfed one's don't like the price tho.
Check my build thread out for my vr its in the new posts at the min so easy to find
I carbon wrapped the 3 piece scuttle panel so you should be able to see what it looks like , i could even do it for you if you wanted to post it
results look blady good! im guessing the 3m wrapp is prety thin and easily workable with heat then?, thanks for the offer anyway.
Yea its the 3m stuff , make sure its cleaned down really well and completley dry before fitting and also try not to stretch it as much as you can in to the swages as it will give it a better chance of staying down
Your welcome mate
The 3M stuff is great, I've wrapped some stuff on the Beemer with it. My only piece of advice is don't stretch it too much and take your time and you're good to go.
