scorrado123 10 Posted February 16, 2013 Hi all, A quick question for you. I want to fit some speakers to my rear parcel shelf instead of using the standard rears. My question is if i want to use the existing wiring to the head unit do I have to cut the rear connectors off as some have suggested on here? Is there a way I can just extend the wires without having to cut off the connectors? Thanks! Quote Share this post Link to post Share on other sites
guildmage 11 Posted February 16, 2013 I believe you can use something along the lines of: http://www.ebay.co.uk/itm/PC2-805-Volkswagen-Speaker-Adaptor-Lead-Cable-Stereo-CD-/150566801843?ssPageName=ADME:L:OC:GB:3160 You may find this item much cheaper somewhere else thought. 1 Quote Share this post Link to post Share on other sites
scorrado123 10 Posted February 16, 2013 I believe you can use something along the lines of: http://www.ebay.co.uk/itm/PC2-805-Volkswagen-Speaker-Adaptor-Lead-Cable-Stereo-CD-/150566801843?ssPageName=ADME:L:OC:GB:3160 You may find this item much cheaper somewhere else thought. Thanks, sounds like just what im after! Quote Share this post Link to post Share on other sites
krishen 2 Posted February 19, 2013 I believe you can use something along the lines of: http://www.ebay.co.uk/itm/PC2-805-Volkswagen-Speaker-Adaptor-Lead-Cable-Stereo-CD-/150566801843?ssPageName=ADME:L:OC:GB:3160 You may find this item much cheaper somewhere else thought. Now that is a brilliant idea. In the past ive always just cut the connectors off. And at £2.05 it's cheap as chips. Will definitely use something like this in the future. Quote Share this post Link to post Share on other sites
scorrado123 10 Posted February 20, 2013 Hi all, just to let you know I got the connectors today from ebay and they work perfectly! :) Thanks guildmage!! Quote Share this post Link to post Share on other sites
