VR6Pete
Have I got the right thing?
Hello mate yes that is the correct bush for the VR6 as they have a 19mm front anti roll bar,
the G60, 16 valvers and the 8 valver Corrado's have a 17 to 18mm front anti roll bar.
The only one question I will ask is have you lowered the car at all,
as the standard bushes aren't as good when they have more pressure put on them from lowered suspension.
You can obtain heavy duty bushes if you require them in the future,
I replaced mine with SuperPro Polyurethane bushes which are harder and can take the extra pressure,
from having the car suspension lowered.
The company I bought them from was C&R Enterprises
Hope this helps.
Si :thumbleft:
Cheers mate. It's a smidge lower than stock, it may even go higher yet due to my drive, always ran standard bushes on my previous VR's that were slammed with no issues, I'm just doing a sub-frame overhaul on mine at the moment and still collecting the many parts :)
Oh cool, make sure you replace the steering rack retaining clamps as they corrode some times,
and regrease the shoulder on the bolts with EP grease and use thread / lock tight on the threads of the bolts as it keeps dirt & moisture out,
and there will be less chance of them working loose.
This will make it a lot easier to undo next time.
Si :thumbleft:
