onestep 0 Posted March 14, 2013 VW 2.0l 16v ABF engine and accessories Covered 45k miles, new water pump, cam belt, cam belt tensioner, spark plugs, HT leads, distributor cap, hall sender, rotor arm, oil filter etc. MK2 gti inlet manifold (Euro type 52mm?? the largest one) MK2 gti injection system, metering head, injectors, fuel filter, ISV etc. (with K&N air cleaner) Fitted with KR cams (from the MK2 16v gti) - ABF cams also included Spare ported and polished KR head (couldn't find the time to fit it!) Re-conditioned alternator and starter motor Full assortment of engine mounts for MK1 gti, including a polyethylene rear bush (front If I can locate it!) The necessary wiring loom for a MK1/2 conversion including two working ECU's New clutch and flywheel MK1 gti 5 speed gearbox (code unknown) £550 ono. Engine located near Peterborough, Cambs. This engine worked flawlessly in my MK1 before removal to make way for a 20v turbo! Would make an ideal upgrade for a 1.8l 16v or as I did, for a conversion. You can't beat the induction roar of a K-jet 16v, especially the 2.0l 16v with KR cams! :) Please email [email protected] if interested THIS COULD BE IDEAL FOR MANY DIFFERENT CONVERSIONS, BUT PLEASE DO YOUR HOMEWORK FIRST COLLECTION ONLY Quote Share this post Link to post Share on other sites
cdem 0 Posted March 27, 2013 I may have a need for the head if your willing to split? Will see how the weekend goes first. I'm in Stamford too so would be able to collect :-) Quote Share this post Link to post Share on other sites
onestep 0 Posted March 28, 2013 I may have a need for the head if your willing to split? Will see how the weekend goes first. I'm in Stamford too so would be able to collect :-) Hi Not sure my friend will split it but he many want to do a deal. Quote Share this post Link to post Share on other sites
