Jim Bowen 1 Posted April 2, 2013 The gauge on my dash has read low for ages. Barely makes it past 70. Unless I sit with it at idle for a while. Seems to rise after a bit and it gets hot. But goes back down to under 70c when driving. The fans come on ok and oil temp is ok. But got this suspect head gasket or air lock at the moment. Where coolant system is pressurized while driving and seems to blow the coolant out the header tank. Also notice gurgle noises behind the dash and in the pipe from engine block to bulk head. Tried a new sensor at the weekend. Was a gsf one. And its not fixed the gauge. Could it be likely its a duff sensor? Or could something else be a problem. Tried to check the wiring but hardly any if it is visible. Really should get myself vagcom as I see you can test the ecu temp reading. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 2, 2013 Thermostat stuck open dude! Quote Share this post Link to post Share on other sites
Portent 0 Posted April 2, 2013 As above, classic thermostat symptoms. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 2, 2013 Christ. Wonder if this is causing my problems. Might be a cheap fix. Got a spare standard one and spare neuspeed low temp one. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted April 2, 2013 Yeah my temp used to take forever to get up to temp with the low temp thermostat got a standard 80 deg one and all perfect again Quote Share this post Link to post Share on other sites
Stonejag 10 Posted April 3, 2013 Which sender did you replace? I assume the yellow one (now black with a blue stripe if you buy new/VW). Just checking as my car has three :) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 3, 2013 Yeah the yellow one, i also have a black one as the car used to have aircon and thats about the only bit of it i didn't remove. does that matter? i notice some places sell a blanking plug. ---------- Post added at 11:39 AM ---------- Previous post was at 10:02 AM ---------- Bought all my bits to office today, am going to sneak out and fit a new thermostat at lunch time Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 3, 2013 Fitted it now. Was more awkward than I had planned. Nearly rounded a bolt. Anyway. It doesn't seem to of changed anything. It's a weird one. Thinking of taking to a garage next for them to work out. Not just the gauge. But this coolant loss. ---------- Post added at 8:40 PM ---------- Previous post was at 8:39 PM ---------- How important is the aux water pump. Seems to be on constantly. Can I drive with it disconnected? Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted April 3, 2013 Have you had it on the vag-com to see the actual temperate the ECU reports? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 3, 2013 No. I've not got round to getting it yet. Do I buy an ebay cable? Is there a certain one I need? Never done anything like that before. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 5, 2013 Popped into a garage lastnight, and they seemed stumped as well. I'm quite sure its headgasket now as can't see anything else and i've changed most parts. They agreed it could be headgasket when i mentioned the noises in pipe from block to heater matrix. Quote Share this post Link to post Share on other sites
Stonejag 10 Posted April 5, 2013 Jim Bowen said: How important is the aux water pump. Seems to be on constantly. Can I drive with it disconnected? It should be on as long as the ignition is on, plus some afterrun. Don't think it's that vital, mine's been jammed for months :lol: Stone Quote Share this post Link to post Share on other sites
