hulk hogan123 10 Posted April 8, 2013 Hi guys, ive read that 18's are a no go on corrados but i'm a little confused as the figures do add up. 18" et35, 5x 100 standard corrado tyre : 205/50/15, rolling radius 293mm, circumference, 1841mm 215/35/18 : rolling radius 303mm, circumference, 1909mm now i know that alot of guys run the 17 " 205/40/17 : rolling radius 298mm, circumference, 1872mm does that 30mm odd on a circumference make that much of a difference? Quote Share this post Link to post Share on other sites
emu 0 Posted April 8, 2013 18" on a rado are possible no problem. Quality of ride and handling due to weight of the wheel is a different story. I was in a rado with fitted 18" ultra light team dynamics and 225/40/18 and honestly for me ride was fine, no as good as on 16" speedlines and 205/40/16 or 195/40/16 can't remember. All depends from the wheel. I have 17 rh zw1 for corrado and they seems heavier then my 19" carlsone 1/16 from my daily. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted April 8, 2013 Look too big as well IMHO... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted April 8, 2013 Anything over 16" completley f*cks the ride quality up... it just wasn't designed for that size wheel Quote Share this post Link to post Share on other sites
clumpy1 11 Posted April 8, 2013 Anything over 16" completley f*cks the ride quality up... it just wasn't designed for that size wheel Absolutely correct . Quote Share this post Link to post Share on other sites
emu 0 Posted April 8, 2013 on 18 Mine without tyres :D Quote Share this post Link to post Share on other sites
hulk hogan123 10 Posted April 8, 2013 any issues with rubbing? w2hat size tyres are you going to run? Quote Share this post Link to post Share on other sites
emu 0 Posted April 8, 2013 215/35 front and 225/35 rear but because of rears being 9,5" and you need min 15mm spacers to go from 5x100 to 5x130 serious arch work is needed but it is possible I have been running 17x9 with ET 0 in the past, so it is possible Quote Share this post Link to post Share on other sites
