nia573 0 Posted April 9, 2013 Having a garage clearout of various abrasives: Ive got lots of these so make me an offer on any amounts you need Shown some prices as a guide but can do a deal on quantities posted Foam drum & sanding belt for drill 130mm dia x 65mm wide Comes with a 8mm dia mandrel (slightly tarnished) to fit in chuck £2.30 each Ive got various silicon carbide discs Ideal for stripping off underseal, rust, cleaning the bottom of the boat etc without damaging the under surface 65mm dia x 15mm wide with a 6mm dia mandrel 75p each 60 to 65mm dia x 10mm wide x 10mm hole for mandrel 5 for £2 100mm dia x 15mm wide x 10mm hole for mandrel 5 for £2.50 These are 75mm dia x 15mm wide with a slight threaded protrusion on reverse as shown (can be held in a drill chuck) £4 for the 8 I have Irwin face off silicon carbide disks for grinders (all have 22mm dia bore) 7” £4.50 each 6” £3.25 each 4” £2.75 Face off 5” solid pad (for hook & loop backing pad) £3 Unbranded 6” solid pads (for hook & loop backing pad) £2.50 each Poly-X packets 125mm diameter (for hook & loop backing pad) £3.50 125MM DIA SILICON CARBIDE DISC (FOR HOOK & LOOP PAD) £3.25 7” flap disk 22mm bore (fine 120 grit I think) £2 7” flap disk 22mm bore (fine 120 grit I think) £2 Ive also found these Grinding wheels for a bench grinder I presume 150mm/ 6” dia x 20mm thick & have a 20mm bore The green ones (8 avail) are Id class these as fine & the grey one is medium/coarse £5 each 125mm/ 5” dia x 20mm thick & have a 20mm bore Again Green (fine) & grey (medium/coarse) available £4 each All items can be collected or posted signed for for peace of mind Mike Bangor N Wales mike@mroberts99.fsnet.co.uk Quote Share this post Link to post Share on other sites
