christopher corrado 10 Posted April 26, 2013 (edited) Hi I have a 1990 G reg16v corrado and have been experiencing engine cut out after about 15 mins of driving. I have noticed that the fuel pump under the rear axel begins to whine just before the engine cuts out, could this be a fault with that pump, a blockage, or the other one in the fuel tanks gone causing this one to become over worked. Any advice would be greatly appreciated, thanks Chris. Edited April 26, 2013 by christopher corrado Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 26, 2013 I'd check the lift pump tank strainer and you main pump and accumulator, does sound more like the lift pump than anything, how much fuel is in the tank? Quote Share this post Link to post Share on other sites
christopher corrado 10 Posted April 26, 2013 Ok thanks for Tue reply. Do you know how to access the lift pump. There's about half a tank of fuel in Tue car currently. davidwort said: I'd check the lift pump tank strainer and you main pump and accumulator, does sound more like the lift pump than anything, how much fuel is in the tank? Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 26, 2013 remove the boot carpet, undo the screws holding down the black floor access panel and then struggle to turn the fuel tank cap, I ended up having to hammer mine around, bit difficult as it's a plastic cap, need to be careful not to damage it too much. Quote Share this post Link to post Share on other sites
christopher corrado 10 Posted April 26, 2013 Ok thanks a lot for the info. I'll have a go at changing it over. davidwort said: remove the boot carpet, undo the screws holding down the black floor access panel and then struggle to turn the fuel tank cap, I ended up having to hammer mine around, bit difficult as it's a plastic cap, need to be careful not to damage it too much. Quote Share this post Link to post Share on other sites
