DubGarry
no spoiler or sunroof
So before I came to worthesee I had a fully functioning sunroof and spoiler and then both of them stopped at once. Spoiler is stuck in the up position and sunroof wont work at all :( spoiler doesnt work manually at all with the switch either
What could it be
Yeah definitely mate with the spoiler stuck in the up position it says to me that the fuse has blown on the way down. Probably due to the spoiler mechanism needing greasing etc. When my spoiler fuse blew it took out the sunroof and the ABS light aswell.
Fuse is a 15amp one it will either be number 16 on the fuse panel or 21 on the fuse panel.
If the fuse keep on blowing and you still want use of the sunroof remove the rear panel black panel on the inside of the tailgate (boot) and pull the spindle on the spoiler mechanism this should stop the spoiler raising and stop you popping fuses till you get chance to look at it when you get back home
