tony_ack
Full Closure not working on driver's window
Not sure whether this belonged in exterior or interior (or ICE and secure for that matter). Though since I'm standing OUTSIDE the car when I activate the C/L...
I have a weird an intermittent problem with the full closure on the driver's window. I have remote full closure on the alarm, and it always closes the sunroof and passenger window fine, but occasionally it won't close the driver's window. It doesn't matter whether I use the key or the fob, it just doesn't close. The window works fine under normal operation, no slow-ness or anything.
Any ideas?
I've had a look at some wiring diagrams, and there's nothing obvious coming in or out of the control module that could cause the symptoms I have.
The window operates fine on the switch
The C/L and full closure work on both the sunroof and the passenger window
So the module is getting power, it's getting the signal from the C/L and the connections to the motors are fine. I can only think the module itself is faulty/
