JohnCarlos
Green 2.0 16v for £1500 in Edinburgh
I am having to sell my project car, as I am starting a new job in August and will be unable to enjoy her once working. I bought the car in April 2011 and have undertaken a significant overhaul to bring her up to standard, with some of the work completed shown below.
Good bits
Engine runs well, and pulls strongly on the road. No knocking, smoke or misfires etc.
Passed its last mot no problems, but has been declared on SORN since May 2013.
Interior condition is excellent, with a new oil pressure gauge fitted recently.
All receipts for the car including previous Mot’s since 1995
Mint condition aftermarket alloy wheels with four good tyres
Brakes refurbished with braided brake lines and callipers painted
Spoiler and sunroof work as new (common faults on the corrado)
A re-spray undertaken prior to my ownership means that the body work is rust free and in excellent condition
Full DVLA history obtained
Bad Bits
Oil pressure light illuminated in dash – but oil pressure gauge reads ok pressure, so fault finding required
New lambda sensor required
Has no current Tax or Mot
Recent work completed
Front subframe replaced
Water pump replaced
Full brake calliper and line overhaul including stainless steel braided brake lines
Exhaust rubber replacement
ARB Mounts replaced
Gearbox mount replaced
Power steering unit refurbished and boots replaced
Track rod ends replaced and tracking performed
Both front wishbones replaced including bushes and ball joints
CV joint boot replacement and re-lubrication
Points cleaned up
New dizzy cap, HT leads, rotor arm, sparkplugs
New Battery
Idle stabilization valve clean up
Temperature sensor and oil sensors all replaced
Oil, oil filter, coolant, air filter replaced
Edited by JohnCarlos
