ray_vr6
23 years old and counting
Just got my 1990 16v back from the garage with another years MOT! so ready for the road again next week.
While it was off the road over the winter period I have done or have had done, the following:
1. Fitted Refurbished Front Sub Frame
2. Replaced Ball Joints
3. Replaced Front Wheel Bearing
4. Replaced Front ARB Bushes
5. Replaced Front ARB Drop Links
6. Replaced Wishbones (new bushes fitted (R32 rear))
7. Replaced Tie Rod Ends
8. Replaced Engine & Gearbox Mounts
9. Fitted Weitec Spring Raising Kit To Rear (25mm)
10. Changed Fuel pump/Accumulator/Filter/Pipes
11. Replaced Oil Pump
12. Replaced front spoiler grill
13. Replaced Cracked Fog Lamp
14. Replaced Faulty LCD Unit
15. Replaced Faulty Indicator Stalk
16. Refurbished Alloys
17. Re- sprayed Front Bumper
18. Repaired Seat Bolster
Needless to say it did not require anything done for The MOT!!
Well done, that's some list of work, get a members thread started to record progress.
I knew I had to change the subframe so it seemed the obvious thing to replace all the bushes etc. I used mostley Lemforder bits (ball joints, drop links,bushes, tierods) and genuine VW wheel bearing.
Looking forward to putting the handling to the test on Highland roads!
