daveb142
2.0l 16v 9a Parts
As i'm converting my corrado to a 20vt, I am selling parts from the 2.0l.
- 9a Inlet Manifold (including injectors and fuel lines) - £40 posted ono
- 9a Throttle Body - £30 posted ono
- Metering head and intake pipe - £35 posted ono
- Coil Pack - £20 posted
- ISV? Or idle control valve? £35 posted ono
- 9a engine 170k, fsh upto 161k, no knocks, bangs or smoke. £100 ono
Can do offers if want multiple items! e.g isv + inlet etc.
If engine doesn't sell as a whole, will break for parts!
Feel free to ask questions.
Dave
Hi,
I'm after a pedometer (048133154). Can you part that out? If that doesn't fix my issue, maybe a ISV? Or even the Lambda sensor!
Where are you based, as there is something up with my car, but don't want to buy all the parts it could be. Might be good to swap a few about?
Errm, what is that exactly? aha. Will have a look dude! Got ISV, lambda snapped :( sorry dude! Based in Plymouth!
Also I have a Catalyic converter if anyone needs one. £35 posted.
The Pedometer? It's on the bottom on the MAF. Tells the ECU if the throttle is shut or open.
Ohhhh, you mean the potentiometer? On the bottom of the throttle body?
---------- Post added 9th June 2013 at 12:25 AM ---------- Previous post was 8th June 2013 at 11:45 PM ----------
how much for the metering head and pipe (is this for all of it up to the throttle body ?) along with the ISV...?
Hi mate, yes that's it including the hose up-to the throttle body and pipe with isv..
Metering head comes with full airbox.
Would do both for £65 posted?
