little andrew 0 Posted June 9, 2013 (edited) 1994 L reg 136,136 miles Mot till 17/06/2014 (no advisories) Tax till 31/08/2013 For sale is my much loved Corrado VR6. I have owned it for just over 3 years during which time £0,000s has been spent. Full black leather interior with heated seats, central locking, immobiliser, electric windows, tilt and slide sunroof (occasionally doesn't slide all the way back but most of the time is fine), rear spoiler works as is should and with the button. Full respray in summer 2010 and garaged pretty much ever since so the body and paintwork look immaculate, I've only done 4,00ish miles and it has been off the road during the winters. During the last 3 years it has had: both engine mounts plus the gearbox mount, track rod ends, passenger wheel bearing,drivers wheel bearing, drivers hub, drivers ball joint, drivers caliper, rear brakes hoses, brake pipes front to back and rear side to side, rear discs and pads, rear caliper, brake disc shields all round, sunroof repair kit, sunroof seal, genuine vw carmats, window rollers (forum group buy), new vw and vr6 badges, new headlight lense, handbrake tunnel bracket (forum group buy), starter motor, bumper grille, dash bulbs, thermostat, plug leads, four wheel tracking, rear wheel bearings, front anti roll bar linkages, wax oiled, water pump + fresh coolant, front abs sensors plus oil and a K&N panel filter. Plus lots of old receipts and stamped service book. It does have a stainless steel back box make unknown and lupo style wiper blades fitted by a previous owner butdon't look out of place. Car was Hpi clear when I bought it and I do have the original side rubbing strips to go with it. Also includes a kenwood cd player with remote control. Only two bad points to mention, first since I wax oiled it over the winter the abs light now comes on, its fine on start up, goes on and off as it should but once you reach 15mph and it does its speed check it buzz's and comes on. Second bad point is the passenger side door card could do with a re-trim as its been damaged and repaired at sum point. Overall the cars a pretty immaculate original vr6 which looks and sounds amazing, I did intend to keep for a long time but a recent house move with lots of diy to come and a baby on the way force a reluctant sale £3100ono Tel 01673849431 or 07880512841 Edited June 14, 2013 by little andrew Share this post Link to post Share on other sites
