aminder
MK3 Golf R32 Manifold & Downpipes for Conversion
Was fitted to a MK3 Golf R32 engine conversion.
Ran pretty close to the engine so should have enough clearance for a MK2 Golf and Corrado.
It has 4 lambda boss's welded for pre and post cat lambda's - the rears can be blocked off if having the rears coded out.
Will also supply a bracket which bolts to the subframe and exhaust rubbers to secure the exhaust at the front
£300
Collection from Leicester.
(I work around Heathrow area so could meet someone at services along the M1 or M40)
