dcrcyclan
window regulater
trying to change my window regulater, but the window is up. how do i get the window down or seperate it from the window so i can take it out.
The regulator is secured to rollers mounted in a channel secured to the bottom of the window. The legs of the regulator have ball connectors which are popped in and out of the rollers. Just be careful the window doesn't plummet down once you disconnect it, ideally get someone to hold it in place or tape it securely.
