rishi
advice on turboing my corrado vr6
Hi all, i am a bit confused and needed some advice. i have a 1995 corrado vr6, i want to turbo the car but not wanting to change pistons etc.. what would i need to to this, i understand i will be running low boost but im unsure on where and what kit i need. any help would be much appreciated.
Speak to Stealth Racing. They do a kit for Corrado VR6's :) Not sure if you can buy the kit and install it yourself, or whether they only sell it as a complete package.
There is a whole thread dedicated to turboing and supercharging the VR in this part of the forum.
Basically though yes you can do that and all you need to do is fit a spacer head gasket to lower the compression ratio. You then need all the other bits for the turbo i.e. turbo, exhaust manifold, wastegate, injectors, intercooler, assocated oil/water lines, remap and a efw other bits like ARP rod and head bolts.
Or got to Stealth and they will do it for you for probably about £5-6k now.
