p0l1wrath
Oil filter housing
After checking the bentley, (slightly different setup) it seems as though the silver thing on the bottom of the oil filter housing is in fact a drain plug? Is this correct?
I have never realised this probably mainly because the hole in mine is rounded, i assume its usually an allen drain plug is it?
cheers
