borarob 0 Posted September 6, 2013 what size are they? i want to fit my RX2 but the bolts holding on the current borbets are taper i believe and i need some radius ones. I found a load in my garage but they must be from a later VW as they are too big to pass through the wheel. cheers! Quote Share this post Link to post Share on other sites
SammyMK3 10 Posted September 6, 2013 What model is your corrado? I believe you need 12x24 1.5 thread pitch. You can double check on VW parts website such as http://store.blackforestindustries.com/wheels2.html They always post good bolt specs on there. Hope that helps. Quote Share this post Link to post Share on other sites
Ruggy 10 Posted September 6, 2013 ****, I've got Borbet C's to fit as my winter wheels, my summer wheels are BBS RS771. I'm guessing thus means that my bolts from the BBS wheels are not gonna fit the Borbets?! Quote Share this post Link to post Share on other sites
GlosterOx 0 Posted September 6, 2013 When I fitted my MK3 Anni RX2's I just used std Corrado VR6 wheel bolts? Ian. Quote Share this post Link to post Share on other sites
leon263 0 Posted September 6, 2013 (edited) As a general rule of thumb, standard fitment VW wheels use radius bolts while after market wheels use tapered bolts. If your wheels are four stud, you need M12 x 1.5 bolts. If your wheels are five stud, you need M14 x 1.5 bolts. Edited September 6, 2013 by leon263 Quote Share this post Link to post Share on other sites
Ruggy 10 Posted September 6, 2013 Good to know Leon, thanks for the info mate. Looks like I need to get on eBay and order some tapered bolts for the Borbets Quote Share this post Link to post Share on other sites
borarob 0 Posted September 7, 2013 Cool that explains it, I must have m14 radius and I need m12. 94 valver 4 stud As has been said oem wheels will be radius, after market will be taper. You don't want to be mixing and matching people, dodgy. Quote Share this post Link to post Share on other sites
Ruggy 10 Posted September 7, 2013 What's the length of standard bolts? Quote Share this post Link to post Share on other sites
borarob 0 Posted September 9, 2013 i think they are 25mm? Quote Share this post Link to post Share on other sites
borarob 0 Posted September 9, 2013 When I fitted my MK3 Anni RX2's I just used std Corrado VR6 wheel bolts? Ian. see Leons reply above Quote Share this post Link to post Share on other sites
