pettsy
1992 2.0 16v 9A Parts Clearance
Having a clearout of my unit, and have the following bits left over. Would rather sell them cheap for some beer tokens than burn them/throw in scrap bin.
Located near Matlock in Derbyshire. Can post smaller items via postoffice
Feel free to text/call: 07944 884008
Pettsy
9A starter Motor
9A Head
9A Gearbox
9A Power steering pump
Power Steering Pipework & tank
Drivers/Pass Window regulators
9A Throttle body
9A in-tank pump
9A ECU
Flash Red Filler Flap
Bonnet Hinges
Front Bumper Brackets
Rad Fan Relays
Complete Lock Set
Grey Parcel Shelf
Boot Lip Plastic Trim
Lower Windscreen Trims (3 pieces) broken clips,were stuck on
15" Spacesaver
Driver/Pass Door Glass
Upper Steering Column Surround
Rear View Mirror
Drivers/Pass Doorhandles
Drivers/Pass doorhandle pull surrounds
Throttle Cable
Column Stalks
Central Locking Pump
9a radiator fan
Header tank
Heated rear window switch
Spoiler switch
Cigarette Lighter
ABS bulb
Electric Window Switches
£20 delivered for power steering pump?
Parcel shelf is in good condition iirc
open to offers on the doorhandles as one doorhandle has a different key to the rest.
Hi there, when you say complete lock set do you mean doors and boot barrels with one key? :scratch:
cheers Alan
cheers Alan
I have complete pair of doorhandles,a boot barrel and a complete steering column. One doorhandle has a different key to the rest as i assume it was replaced at some point. iirc it isnt a major job to retumble this lock to match the rest.
Have you got a pic of the window switches Mate ??
Will dig a pic out tonight.
Pm sent re doorhandles.
pm replied
Any chance you have an alternator 90A?
i dont think ive got the alternator but will double check for you this afternoon
Hi,
Is the power steering pump still available...thread seems quiet for a clearout? I have a 92 2l16v, I've put back on the road after being rested for 6 years and I need a few bits...
Hi,
yes, i think i still have the power steering pump. Does it need posting or can you collect?
Is the power steering pump still available? Also was it still "silent" as in not making a horrible whiney sound like mine when you took it off the car?
