__Andy__
Subframe and rear beam...
As title then im after a front subframe and a rear beam for a 9a valver, must be in good condition ie: straight and not from a car thats half an inch off the ground!
i appreciate most will have surface rust, this isnt an issue as they'll be getting blasted and powder coated. Do not need steering rack or arms with the subframe just the block weight and arb, as for rear axle im easy as to how that comes.
Can collect within reason, if not then courier will be needed.
What have you got?
Regards,
Andy
Devon Dubshack in Plymouth has a k reg 2.0 9a corrado in for breaking if you're still looking. Tel 0136473038
