VR6 Lee 0 Posted September 30, 2013 I have got the gauges but what other parts do I need? Just wondering where the best place to get the bits I need so I can fit them in over the winter months Many thanks in advance Lee Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted September 30, 2013 Lee, you can get the dual pole sender from Berlin Motorsport, the connector for the back of the gauges and 2 repair wires can be bought from Vw/tps. Dead easy to fit. Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted September 30, 2013 Wesleyvr6 said: Lee, you can get the dual pole sender from Berlin Motorsport, the connector for the back of the gauges and 2 repair wires can be bought from Vw/tps. Dead easy to fit. Are they specific part numbers? Where you based in Stockport? Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted September 30, 2013 Wesleyvr6 said: Lee, you can get the dual pole sender from Berlin Motorsport, the connector for the back of the gauges and 2 repair wires can be bought from Vw/tps. Dead easy to fit. Take it you meant merlin motorsport Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted September 30, 2013 Haha yes! Stupid iPhone! Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted September 30, 2013 Wesleyvr6 said: Haha yes! Stupid iPhone! No worries Which sender, there are loads of types Quote Share this post Link to post Share on other sites
Wesleyvr6 10 Posted September 30, 2013 Yes I'm Stockport, bought your wheels remember! I will have to dig my invoice out mate to get the part numbers. Quote Share this post Link to post Share on other sites
jscVR6 0 Posted October 1, 2013 I got my oil pressure sender from VW Heritage, found they were the cheapest: http://www.vwheritage.com/vw_spares_Oil-press-sender-150psi-Gauge-6-9psi-switch-2-pin_act_shop.product_pID_90289_lang_EN_country_GB.htm And I think the connector is still available from VW: 1J0 972 704 Connector housing x1 000 979 133E Connector pins x2 (come as 2 pieces of wire with a pin on each end so you need 2 and cut in half to make 4 connectors) Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted October 1, 2013 jscVR6 said: I got my oil pressure sender from VW Heritage, found they were the cheapest: http://www.vwheritage.com/vw_spares_Oil-press-sender-150psi-Gauge-6-9psi-switch-2-pin_act_shop.product_pID_90289_lang_EN_country_GB.htm And I think the connector is still available from VW: 1J0 972 704 Connector housing x1 000 979 133E Connector pins x2 (come as 2 pieces of wire with a pin on each end so you need 2 and cut in half to make 4 connectors) So everything for the above is for oil pressure and the volts bit?? Quote Share this post Link to post Share on other sites
jscVR6 0 Posted October 1, 2013 Yep that's everything you should need, although you might want to order a couple of speed nuts that clip into the centre console to screw the gauge panel into p/no N90282501. Wiring is as follows: G. Druck = Pressure sender feed 15 = Ignition live 31 = Earth 58 = Dash illumination There's all the information you need on this thread too: http://the-corrado.net/showthread.php?t=13167&highlight=VDO+Gauges Quote Share this post Link to post Share on other sites
