Alastair
Front suspension top mount
I've had imprecise handling and uneven front tyre wear for the past few months. I jacked up the front end and found that the strut top mount dropped a 1/2 inch or so and moved around, but seated back OK when the weight was on it. Is this normal? I'd have thought it should be fixed.
TIA
Ali.
Yep that's normal. When you take the weight off the front wheels there's a fair bit of movement. New top mounts won't hurt though if they haven't been changed before....
Don't think they've been changed. It got 100k miles on clock, so I reckon they've had a good life. Is it straight forward to replace them? Anyone got a link to a procedure anywhere?
