Matt@OCD 0 Posted November 4, 2013 Finally got things sorted out with this, taken longer than I would of liked! We all know how hot our G60's run and this is one of my first recommended modifications I advise people, on stock engines or lightly tuned it's the place to start personally. Kit consists of the cooler, we have either 10 Row or 13 Row, 4x push fittings, 1 metre oil hose, universal fitting kit & Mocal thermostatic plate. http://www.onlychargeddubs.co.uk/products/g60-g40-oil-cooler-kit.html We've also got available the factory oil/water cooler deletion coolant pipes, this is something else we recommend, it prevents any chances of oil and water mixing and stops the oil being warmed by the coolant temp, it brings both down and helps massively on tuned engines and in the summer months, this keeps engine health up and prolongs the life of the bearings in the supercharger. People also find if the oil/water cooler is kept the factory oil filter can catch on the cross member, one solution people have done is using a shorter oil filter but this isn't a great idea as it reduces oil flow on start up http://www.onlychargeddubs.co.uk/products/g60-oil-cooler-deletion-coolant-pipes.html To go with both the above is the shorter thread for the oil filter as the one with the oil cooler is too long for just the sandwich plate http://www.onlychargeddubs.co.uk/products/oil-filter-short-threaded-union.html Matt Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted November 5, 2013 Hi Matt, The kit you posted, is this a complete kit with all the bits included as in the pictures? Also would you be able to fit this kit to a standard Corrado G60, and how much would i be looking at fully fitted. Thanks Quote Share this post Link to post Share on other sites
Matt@OCD 0 Posted November 6, 2013 Sanky, Yep, it's all included :) For the full kit including deleting the factory oil cooler it will be £340, this will include new oil filter and topping up oil and coolant lost doing the swap. Thanks Matt Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted November 7, 2013 Cool, will be in touch as soon winter is over. Quote Share this post Link to post Share on other sites
Jim 2 Posted November 7, 2013 Great to see companies still springing up to support the venerable G60 with great kits like this - nice one :) Quote Share this post Link to post Share on other sites
Matt@OCD 0 Posted November 7, 2013 Look forward to it Sanky! Cheers Jim, there's plenty more to come too! As well as parts for VR6 :D Quote Share this post Link to post Share on other sites
Jim 2 Posted November 7, 2013 Matt@OCD said: Look forward to it Sanky! Cheers Jim, there's plenty more to come too! As well as parts for VR6 :D Ooh - cool - I'll keep an eye out for those then! Quote Share this post Link to post Share on other sites
G60 CS 0 Posted November 7, 2013 I run a full 13 row Mocal setup on mine highly recommend them Quote Share this post Link to post Share on other sites
