vw bobby
Audi S2 Inlet for KR engine
Hi All,
I have an Audi S2 inlet manifold that has been modified to fit the VW popular 4 cylinder 16v engines such as the ABF, KR, 9A etc there is no fuel rail injectors.
It has had one of the runners removed and a flange welded on with the bolt pattern of the ABF/2E throttle body. (TB may need slight modification to fit).
Welded on the underside is a plate to allow fit for the std VW 1.8t inlet sensor, two vacuum nipples, an AN 8 fitting, two mounts for a bracket and on the end a take off for the brake vacuum pipe. Lugs welded onto the runners are for a std 1.8t fuel rail and injectors to bolt to.
A rare item perfect for people wanting to turbo or supercharge their car.
Located in Hounslow, Middlesex, London.
Looking for £350
Cheers
Bobby
