sheppeydave
Corrado main beam ****
Hello all I have a corrado 16v with a uprated wiring loom and it's perfect on dipped lights but when I go to main the dipped headlights go
Dim and main lights come on dim any ideas???
You should have a relay controlling dip and main beams. I suggest you check the ground from the relay kit to make sure it's clean and nice and then try swapping the relay from the main beam circuit to the dip beam. This should bottom out whether it's dodgy wiring, or a dodgy relay.
