lowvr 0 Posted January 23, 2014 this is ideal for anyone trying to achieve big power on a forced induction vr6 or even for someone after closer ratios for the n/a for a better sprint based car. includes: 6spd 02m drp gearbox - already has a 6cylinder bell housing to mate up directly to a vr6 12/24v engine. the drp based boxes are known to be the strongest of the choices 6spd gear shifter with all linkages c2 motorsport 02m gearbox mount to negate the need for chassis leg based mounts allowing fitment in vehicles such as golf mk2/mk3/corrado etc vr6 front subframe with wishbones which has had the gearbox cup relocated to allow use of the c2 motorsport mount for drive axel clearence. everything is in full working order and a little bit oily/mechanical dirt. i was planning on having everything freshly powdercoated before putting this up for sale but realised it would only add to the sale price. As it is you have the choice to either leave it functional and dirty or paint/powdercoat/anodise/polish in what every colour scheme you wish. this set up does not include any driveshafts as you have a few choices depending on your intentions for this: - if going 4wd you will need custom length driveshafts - if keeping it fwd you have 2 choices again: 1. use the 02m transfer box to help create driveshafts of equal length to aid with torque steer issues or maybe in anticipation of a 4wd conversion. 2. remove the dead weight of transferbox and keep it fwd. here a stock skoda drive shaft + a custom driveshaft can be used. all custom driveshafts can be made to a higher spec than standard from a range of fabricators or a cheaper option is to shorten and balance your original driveshafts from an experienced engineer (if you require help i can pass you some contact details) PRICE: 600 LOCATION: leicester le4 ...can have transport arranged around the country if required at cost. CONTACT: 07734931385 (call r text if interest is genuine Quote Share this post Link to post Share on other sites
quicky1980 0 Posted March 9, 2014 would be interested in the c2 mount and subframe if you decide to split Quote Share this post Link to post Share on other sites
