PhatVR6
Does this sound like a fuel pump fault to you?
Can fires up and idles fine, and runs fine for a mile or so. I can boot it, but only once or twice, then once I've done that, it feels like it's running on 5 cylinders. If I let it cruise a while, and give it part throttle it runs fine, but if I floor it, it'll go onto stuttering again.
I'm thinking it's the fuel pump dying, and it can't supply enough flow to sustain high demand?
It was whining a lot when I fitted the VR (it' an 8v pump, same as a VR6 one though). but I took it out and agve it a wd40 spray which shut it up. so that leads me to suspect that it's finally dying now.
your thoughts before I go buy a new one please.
My pump whined for ages, then finally one journey I found I couldnt rev above 5k about 20 or 30 miles later this dropped to 4k, then 3k and after about 60 or so miles, as I was limping home it, wouldn't rev above about 1500rpm.
mine still revs, but it just feels flat like it's running on 5.
oh, and then I ran outof petrol! I was running around trying to get the fuel as low as possible so I could take the pump out, and ran out 2 miles away from home...
