MZpog 10 Posted February 20, 2014 Has anyone produced a guide for fixing the spoiler electrics? What I hope for is some sort of wiring diagram, but detailing where in the car things are......for example, the blue/white wire goes from fuse no 15, traces down drivers side to boot connector. I have a manual with the actual diagram, but was hoping for sommat that would help me diagnose my problem (works on switch, but not speed activated). If I knew where the wires came from/to, I could cut each end and rough wire an alternative wire to find out if this wire is at fault. I know where the control unit is, but would love to know were it gets it's signal from to move the spoiler. Sorry for the rambling of a mad man, but I want a working spoiler and any help would be appreciated. Thanks in advance. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted February 22, 2014 Has the spoiler ever worked since you've had the car? Have you replaced your stereo recently? Quote Share this post Link to post Share on other sites
MZpog 10 Posted February 22, 2014 Always worked on the switch and has an aftermarket headunit fitted, but no connection to the blue/white. Quote Share this post Link to post Share on other sites
stevec14 10 Posted February 22, 2014 HI Hope this helps you. Had to replace my dash clocks with a spare set I have due to a problematic fuel gauge. My spare dash clocks appeared to work perfectly with the car ticking over on the drive. I then took the car out for a drive the spoiler failed to raise at 40MPH ish. Did a little experiment and manually raised spoiler at speed then stopped the car and spoiler stayed up. I then repaired my original dash clocks and the spoiler returned to normal working order. Speed signal must come from the dash clocks to spoiler control module. Steve Quote Share this post Link to post Share on other sites
