leon263 0 Posted March 16, 2014 All prices are plus postage. A pair of undamaged outer plastic triangles form the front corner of the side windows ..... £6 each, £10 for the pair. The outer rubber trim from around the passenger side window. Totally undamaged with no splits. Also include is a roll of double sided trim tape which you will need when fitting it ..... £20 A pair if the inner rubber window trims, both undamaged ..... £9 each, £15 for the pair Quote Share this post Link to post Share on other sites
